I recently aquired a Taco T1oo @ a yard sale for next to nothing. I'm trying to figure out how to disassemble the front fork springs. I think the bottoms twist off.?
I'm trying to widen my forks on my manco thunder bird so i can put a bigger tire on it. anyone have any ideas on how i should do it? i searched but couldn't find anything helpful. thanks.
So I picked up a new bike and the forks are a bit tweaked. One handle bar is pointed in more and there is a slight bend in the down tubes. Is there a good way of correcting this? Or is correcting it called new forks? Input = appreciated!
Thanks
I need a couple sections of tube from Trail Horse or MTD suspension forks,, inner springs style forks..... I'd prefer to have the upper handle bar section(s).
I have to repair some forks and need that o.d size and wall thickness...
I am looking to replace my rigid front forks with forks containing suspension for a little bit more comfort off road. Has as anyone swapped out their front forks? I am looking to see what others have used. I have a murray track 2 that I was looking to do this on.
I have 2 sets of taco forks i am trying to disassemble so i can clean them up and repaint them. They are the upper spring style forks. i have twisted the spring so that the bottom part of the fork is free to come off but it wont pull out of the top part. I have oiled it and tapped it with a...
working on the mystery bonanza and the lower legs slop back and forth fairly much....not enough space to make a shim and wrap around the tube or to insert a nylon liner....
my thought was to put a braze all the way around the lower legs where they fit in the upper half and then use an old...
On the site there is a few minis with an awesome inverted fork setup. Which I'm guessing come from a pit bike. Has anyone tried this yet? Just from an initial search it seems like no one has. Any information would be great.
Thanks
What is this I am bidding on, I really like the shape of it, and it looks very familiar, but I just cant Identify it.
eBay Motors: Vintage mini bike frame (item 180323920725 end time Jan-29-09 15:31:45 PST)
Check out the forks that are bent on the lower bike.
http://www.oldminibikes.com/forum/general-minibike-talk/6452-please-help-i-d-these-two-bikes.html
How do you go about straightening the forks & will they remain straight?
Thanks
