I am getting ready to start working on a kart I purchased. I believe it to be a Tiger Kart manufactured in Mesa, AZ but there is not much out there about them. I have no idea if the kart is original or what has been done to it in the past. My question is in regards to the front spindles and...
I don't have the 212cc yet but when I do get it, is it possible I can get a smaller rear sprocket, so that I can lose most of the wheelie power? how small should/can I go?
I was curious if anybody out there had all of the sizes of every bolt and bushing and bearing on the DB 30 new style? I've got on OldMiniBikes warehouse.com and I can find the parts but they don't list sizes or if they do they don't say where that part belongs for example they have a lot of bushings on...
Hi, could anyone tell me what size oil drain plug (magnetic) to get for the stock engine?
I've got magnetic plugs on all my other toys and would love to know where to buy one for the MB200.
Thanks!
Hello i want to replace the carburetor on the 6.5 hp engine with a high performance carburetor but i dont know the intensification for the carburetor. Can anyone help me?
I have a old Thunderbolt mini muddier and I'm needing a carb for it. Can't find any numbers on the motor. How do I figure how what motor I have? Thanks
Id like to replace the rear axle with a higher quality bolt , someone has rethreaded the end of my axle 9/16 on one end and metric on the other . Looking for the axle diameter , I know its roughly 13.5" long .
Thanks
PH
as the title says I am looking for a doodle bug size roller to a project. I have a motor so really just need the rest of the parts.
let me know what you got!
I am located in the Boston area
Title says it all. How do I get this thing out and what bearings are used? I have an idea on the removal but want conformation before moving forward. Looks like you just remove the sprocket and push the shaft out from right to left (sitting on bike). As for the bearings I am sure there are...
just got my engine put together recently with electric start now i need a minibike friendly battery. I had the Billet flywheel machined to accept the ring gear and everything works nicely now i just need a small power source, wasnt sure if anyone had experience with this.
Say the tire is 21x12x8 ....
or ... 21x9x8
what WIDTH wheel is required to maintain the tire diameter? 21" in both examples.
I ask because my tire currently is 21x12x8 with a 9" WIDE wheel and both front and rear tires are 22-3/4" tall. Too tall for the bike. Tires were measures with 1/2...
I'm building a predator 212. I want to run a tillotson carb but i can't decide between Racing fuel or Alchohol. Which fuel is best and size carb would you run? Price doesn't matter in fuel cost.
MY SPECS:
Predator 212
18cc head milled 0.050 and ported
27/25mm SS valves
billet flywheel...
The bike is a Heald VT-1012 with tire clearance issues in the front and rear.
The bike calls for a 21x12x8 tire.
The Tire that is on the bike is 21x12x8, but when measured for height the tire is 22-3/4" or so .... why?
ATV is noted on the side of the tire, is there a difference between...
I purchased a shotgun header with the screw on bullet muffler adapter from hot rod mini. What size of muffler should i purchase? What is the threading size? The website does not have specific sizes.
Are any of the engines the same outside dimensions with bigger bore and stroke to get a higher hp rating or does the case size just go up with larger displacement engines. reason being trying to buy used engines or machinery to rob an engine from. 3-5hp engines are the same cost as 6-10 hp...
Hello all,
I am finishing a restoration on an Alsport Tri-Sport RTS-SL and I need to drop the diff and replace a broken diff bolt and sprocket mounting nut but I want to buy averything ahead of time. So I was wondering if someone could tell me what size, length and thread diff case bolt and...
