tec
  1. Doc1976
    good deal on a tec 8 HP
    Think I got a pretty good deal on a Tec 8 horse. brand new never run 2007 model i think. Also in the deal was a comet torque converter setup, also brand new. gave 250 for the package. So Its home is going to be a early 60's tule trooper. Couple questions on the motor though. I'm hoping to add an...
  2. Sixpac440
    How do you "break in" a Tec H50 motorsports engine?
    Dumb question that I do not have the answer to!!
  3. slywilliez
    WANTED Big block Tec H50 throttle linkage.
    Need for the bike build off, Big block Tec H50 throttle linkage. Let me know what you have. I have the correct cover, just need the linkage but would be interested in a complete setup also. Thanks
  4. FOMOGO
    Hot Rodding a Tec
    I see people posting about the H50 performance engine and parts. Can you, well I know anything can be done...., but can you hot rod an HM80? Just a mild build. Maybe 12 to 14 horse. To much trouble? No parts? Whats the low down???? Thanks, Doug
  5. A
    5.5 Tec OHV
    I have a 5.5 horse tec ohv engine and I was wondering if there are any performance parts i could use on it. It take the same coil as a predator engine, and the same stock gas tank so i was wondering if it takes the same parts as the predator engines. Thank you in advance
  6. 72shriek
    Briggs v Tec mounting
    Forgive the basic question here, I've been away from small engines and mini bikes for twenty years. Do most of the small engines have a common mounting pattern or are Tecumseh totally different from Briggs small engines? The current cobbled up plate in my Shrike is set for a Briggs I/C 4...
  7. Studeman68
    8HP Tec in Penn.
    Not a bad deal if you can pick up.. Set up for electric start and has an alternator... John Deere TRS26 8 HP Tecumseh Engine HMSK80 155418T Snow Blower Thrower | eBay
  8. FirePowerMinis
    Trickin a Tec for Torque
    Latest recycling find. 139cc HSK845 ringy-dingy, for $6 including the A/V cart and some 1/2 coarse bolts for my van seat. I'm going to add a reed cage, some timing & compression, and trim the intake skirt for better filling, then see if it improves the curve.
  9. Sprocket86
    Tec carb bowl vent help!
    If I delete and cap off the primer bulb nipple on the carb body, will I have to enlarge the tiny vent hole that's drilled in the side of the carbs main body? What symptoms would this cause if I were to leave the tiny vent hole unaltered if the primer line nipple was capped off? I...
  10. Sprocket86
    1972 Tec H35 carb options.
    Unfortunately the original carb on my 1972 DMP Scamper with the TEC H35 engine is shot. Someone over tightened the LS needle and broke off the metering tip of the needle in the carb body :censure: I hear no check ball rattle when I shake the carb body and the throttle shaft has a good amount...
  11. Sixpac440
    Tec H50 New VS Old?
    Is this Tecumseh 5.0HP shortblock (994k) | eBay just a new version of my 1970 H50 or is it a performance built motor? Kevin
  12. bikebudy
    TEC engine paint color
    Hello, I have a Mini Bike correct, 3.5 TEC from 1971 MTD Now its a true engine from a MTD, so the engine was Silver OG. I'm going to repaint this engine and its not going back into a MTD. So, my Question is, Do I paint it Silver again? OR should I paint it Black OR White ...
  13. mlanzoni
    Rebuild Tec H60 ??
    I'm about ready to rebuild a Tec engine, 6 Hp Engine H60 75414M SER 3269D. I installed a new carb kit, but engine still is hard to start, and bogs down under load. I've rebuilt top ends in 2 stroke engines (125cc and 400cc) but never rebuilt a small engine. Where/how is the best place to...
  14. FirePowerMinis
    14cc Honda GX Bare Heads $20 Each Or Trade For Tec Parts
    Bare, cleaned, unneeded. My parts washer solvent discolored some, but it blasts back to shiny. $20 each plus a couple bucks for the mailman, unless you're accidentally in Flint MI. One is a new clone, with mild porting, others genuine. I need billet rods and cams for an HS50 and HM100
  15. C
    Tec 5.5 ohv vs vintage tec 4-5 hp flathead
    I'm curious about what people on OldMiniBikes think about this comparison,Tec 5.5 Power Sport OHV vs. A vintage Tec 4or5 hp flathead. The chosen motor will be going on a Manco Trailcat.
  16. mini one
    Older Tec Recoil Stuff
    The top Three and the new one are complete/working. Everything here for 50.00 plus shipping or trades? Shipped from NY 12302
  17. Biffmini
    Trying to find part #s for tec 3.5 Craftsman labled engine
    Not having any luck. # on cover 143 744012 SER 4031B Any help would greatly appreciated:helpsmilie:
  18. Fisher1983
    Engines and engine parts Briggs Tec Honda
    More goodies for sale, must go. 3.5hp Briggs, needs rings. $30 bucks. 3.5hp Tec long block, $30 bucks. Honda GC160 complete and running, $75 bucks. Baja 97cc with header, 2500 clutch, and carb work, 6hrs run time, great running stocker, $60 bucks. Briggs 5hp parts: Make offer. block, needs...
  19. J
    Taylor muffler Tec H70
    Would like to buy a Taylor muffler for a Tec H70. Thanks
  20. J
    WTB Taylor Muffler for Tec H70
