Hi guys I recently bought a Bonanza BC1300. I removed the 2 lower fork bolts and they wouldn't budge. I pulled as hard as I could and both springs broke in half and the top small piece where the bolt goes through as stuck in each side along with half of the spring. Any tips on getting them out? So far I've sprayed lots of liquid wrench down each fork tube and also tried a torch to heat up the outside of the bars. I then put the lower in with half of the spring and twisted counter clockwise and tried to pull again with no success. What else is there to try? At the very least I want to get the other half of the spring out as for I have replacement springs. Thanks in advance!
