Really nice. I would love to have something like that I could mount on the axle. I don't have a spot for the second attachment point though.
Great work. You have any extras?
KD
No, I make each one to fit the specific bike/frame I'm building...
But they're easy to make...
3/16" plate steel cut to the desired shape with an angle grinder or saber saw fitted with a BLU-MOL blade...
Drill a 5/8" hole for the axle...
Drill another hole in a chosen location for a bolt or pin attached to the frame to keep the plate from spinning when the brake is applied...
Put the plate on the frame, clamp the band to the drum and scribe for a hole to weld the band pin into...
Fab up a small cable stop plate and weld it to the brake plate and it's done...
