A bench grinder/wire wheel, a BFH is a must:hammer:, pry bars,a good selection screw drivers, I can go on and on.:grind::hack::weld:
I like Axes..
Anybody else?? :shrug:
Axes work very well for anything destructive..
a MUST HAVE for scrapping... Especially cars.. I have a double headed axe head with a steel tube about 4 feet long welded in for a handle thats been annealed and WOW that thing works good..
It's SWEET for tearing out wiring.. You can stand outside the car, and give it sharp jabs with the 10 inch long sharp ass head strait into the dash board cluster and in most vehicles just beat the whole dash board rite out of them.. Plastic shredded disaster in the seats and floor boards.. :evil_laughter:
But that will let ya hack out the heater core and air condenser core, and make the 2 inch thick copper wire vane running through there, easy to get at with your snippers.... :thumbsup:
THEN after ya cut the ends all free there, plastic clips and plugs, ground wires, mounting straps all loose so they slide through stuff easily....
Ya take your trusty Axe and slash the carpeting wide open along the floor down each outer edge on both sides and cut loose what ends are grounded and stuff in that big ass 6 foot long 3 inch thick copper vane :drool:
And ya take your trusty Axe and ya tie the wiring harness on the end around that big ole wide ass hammer head :evil_laughter: and ya rip the wiring all out like gutting a deer..
You can get one of those wire clusters that wants to hang up in a hole in the steel body structure or a big ole ground wire ya can't get to.. SO ya tighten your grasp and take up the slack coming off from one end, use the other end as an anchor point, and use the leverage of your 4 foot handle to RIP the stuff loose.. :evil_laughter:
Whats that,
hmy: Big ole Aluminum trim pieces??? :drool:
HAYAH!! :hammer: LOOK AT THAT ALUMINUM FLY!!!
Chop shit in half..
Two seconds flat ya just lopped off 6 pounds of brass screwed onto that water heater.. :hammer:
DAMN that dryer is empty and huge and light weight for space in the truck box... Use this damn Battle Axe to pound 600 pounds of tin cans up it's ass with the hammer head jabber action.. :2guns:
Peal sheet metal wide open with a swat of my Battle Axe... :hammer:
Bust up engine blocks..and cast iron bath tubs (with the dull end )
Split fire wood.....
I have an old like 50's or 60's Estwing hatchet with a rubber handle I made because the leather one had rotted off.... It's like :drool: :drool: sharp... I've got it worked down to sweet wet stone finish SHARP as hell.. That I call my Tactical Hatchet.. :evil_laughter:
I like axes.. :laugh:
Anyone else??
