Well, its been a long time since my last update. Too long really so I apologize for that. Things have come a long long way since my last update. Once the project was moved to my friend's garage at school, progress really slowed and I found myself taking less pictures along the way. Because I am busy doing school work and trying to find a job for after graduation, the small amount of time I had to work on the doodle didn't get used to document its progress very well but I still have a lot to show you. It took me about 2 hours to upload all the pictures, lol.
We will begin where I left off. I had just finished the gas tank. All photos are in chronological order.
In this picture, you can see the tabs I welded on under the tank and how they attach the tank to the bike. Also, it shows the exhaust I made. It was made from a combination of the original exhaust and exhaust part from a Honda xr650 dirt-bike exhaust.
As you can see, I was able to make the exhaust a two piece 2 into one design which makes installation a breeze. Sounds great btw.
So, since the semester started this year, all I have gotten done on the bike at school was I made and mounted the gas tank. Plumbed the fuel system and piped in the breather back to the intake runner for positive crank case ventilation and made an exhaust. No much really. The images that follow were all preformed in my spring break week which started Friday, march 22nd.
Jaimie started making a new seat pan out of some aluminum and we were gonna rivet the original vinyl cover over the stock foam with a little extra stuffed in from an old couch cushion. All that after we cut and modify the cover and foam to make room for the gas tank. Haven t found anyone around locally that will help me with the seat modification tho. I cant sew.
Here is the same technique I used to mount the gas tank being done on the rear exhaust hanger. I get a threaded insert and weld it in. I think it is originally for wood, but I make it work.
In this shot you can see I finally have my 54T sprocket from AGK. Took over 3 months to get it...
Here you can see that I had to relocate the mounting tab for the oil dipstick. I took care not to disturb its height so that it can still give an accurate reading.
