Front sprocket on briggs 5hp horizontal drive?
I am installing a 5hp briggs horizontal driveshaft engine on a baja doodlebug frame. How do I install a front sprocket to the driveshaft.
Thanks
Maybe he doesn't want a clutch and really wants to use direct drive. In which case we'll save him a spot in our "Hi Speed Forks" section. We're just yanking your chain luvgto. Ogy
Welcome luvgto:thumbsup: And thanks Roccosbike for pointing him in the right direction, that's how questions by new members should be answered.:thumbsup:
Thank you for the heads up Ace. From now on I will PM you prior to making any posts to threads from newbies just to make sure I'm answering them in "the right way". Ogy
If you mount the motor all the way to the right side of the the motor plate ( pull cord side) then you will put the sprocket to the outside of the motor and clutch.
If you mount the motor more to the middle or left side of the mounting plate then you can reverse the clutch with the sprocket to the inside of the clutch away from your leg.
Make sure your clutch/ sprocket has a hex nut to tighten to the shaft after you have it aligned to the rear sprocket.
You will find the Briggs forums here have a lot of helpful people as well.
