i thought i would try my skills at building a round gas tank with two oil filters and a old tank that the bottom rusted out for parts(filler neck). also with the help of some of the members advise on how to do it..........:thumbsup:
first thing i did was drill out a 1 1/2 hole for the filler neck and then a small hole for the pit/cock and then cut the two threaded ends off the oil filters and then the rusty tank filler neck. clean all the parts that where to be solder together real good and then soldered everthing up. after the tank cool down. i went ahead and use some gas to check for leaks. i just figure the gas would find the leaks qiucker then anything else and no leaks......:thumbsup: at this point i have not use any tank sealer and really don't have a clue on what works the best when it comes to sealing tank and looks nice inside the tank after it's sealed up....:shrug: i am more thinking of using it for sealing any bare metal spots so it never rust's and to make sure the tank never leaks. so any advise on that would great guys......
this one is for you yellowhand...........
