ok what you want ot do is pay it down with WD-40 let it sit for a few and get a puller or somthing to pull it with maybe a fork (no not your ordinary fork) adn try that or if it still dosent want to come take a die grinder to it and saw that sucker in 2 :gunsmilie:
if its not bottomed out as far as it can go to the motor you can tap it with a hammer twords the motor to break it loose. Then youll know how much force it should take to pull it back off. Sometimes those pulleys have 2 set screws make sure you got them all loose
yikes!!!! did you try taking the clutch apart? pull the C clip on the front ohh never mind you can it is on the other side looks like your screwed LMAO
