Out of the box, I was very impressed with the weight and construction of this devise. It really is a solid piece of work.
I wouldn't expect more if some huge multinational company were producing it. Installation was easy and the install video
instructions were clear and complete. This was fun. The installed clutch operates as described, although it's going to
take some getting used to. I am a very satisfied customer and it was well worth the wait. :thumbsup:
I can think of a couple of things to bring to your attention. They are small but this is why you wanted a test group, isn't it?
1) I had a little trouble with the cable-stop & the short set screw fitting together. The screw threads didn't quite fit through the stop.
With an allen wrench, I screwed it in and backed it out several times before installing it. (screw threads are always bigger than the hole)
2) My standard size allen wrench, used for the cable-stop, was to long to fit between the stop and the clutch. I had to cut it down with a dremel.
I was thinking, if a special size tool is necessary why didn't you include it? Adding this to the kit would help gain customer confidence in the product.
3) The same can be said for the cable-end as well. Isn't there something that the cable-end can be dipped into to prevent fraying? I almost got out
my soldering kit and coated it myself before the install, but the stop-hole looked so small. Does it have to be, can you drill it out a little?
4) I'd really like you to address this chain/clutch guard issue. I'd like to have one but the clutch uses one of the mount holes. Is it possible to slip
the guard mounting plate between the clutch and block (upper left hole), or do I resign myself to using the two remaining mounting holes
(upper-right & lower-left) for mounting a chain/clutch guard? This would suck because no nobody makes one.
Or, maybe you could make one and sell it as an addition, like your engine mounting plate?
Ok, I'll let you go now. Looks like a great piece of work guys and those are all my issues, so far. We'll be in touch... (My life should be so trouble-free.)
If you really want to see my whole installation in one video, click the link.
No full page iframe, I just didn't want to bore or irritate anyone with it...
DBR1 Manual Clutch install - YouTube
