Hi everyone! I just took apart my Predator 212cc engine and removed the governor, then put it all back together. Then I replaced the throttle on my mini bike. Now, the engine won't start!
I currently have the throttle wire leading to the throttle arm, which I still have connected to the governor arm, which leads to the carb. Whenever I pull the wire to start my engine, I can hear it start up, but it won't start!! If I give it a little throttle while starting it then it starts up, but once I let go of the throttle it dies! So it doesn't even idle anymore!
I don't know if I messed up on the throttle component, or if there could be something else. Could too much oil be the cause of this? Because I may have added too much oil.
Anyways, the engine won't start without throttle, and then dies when throttle is cut. Please help!! THANKS!!!
