So on to the test subject. I chose to use my Ruttman for a few reasons, one being that the engine originally came on a snow blower, and I had modified that linkage to work. Functional, but ugly:laugh:
So this is what I started with- look how the arm travels in an arc, but the cable is in a fixed position. It worked OK, but it was always a little sticky.
Installation is fairly straightforward. First remove the two side bolts
Then the three headbolts that secure the cover to the block. (you may have to loosen the front headbolts as well if there is a mounted gas tank like mine)
From there we remove the blower housing and now can access the rivets that hold the old linkage on. Good thing is you can drill them out using a 3/16" bit, and you don't have to remove the flywheel:thumbsup:. Some engines have this part bolted on, so you don't even have to remove the cover.
I like to use a little cutting oil and a nice sharp bit, makes all the difference.
Make sure you clean up the shavings IMMEDIATELY after you drill. You don't want this stiff getting stuck to your flywheel magnets.
:thumbsup:
Here is the old ugly, next to the new nice one:thumbsup:
Installation was a breeze, I just put a couple of pop rivets in from the back side.
Like most of you, my old throttle cable was actually a bicycle brake cable. Now was the perfect time to change it out. I was got ahold of some actual throttle wire (it has finer strands, so it is more flexible) and got some quality cable with a liner inside. A little lube, and it pulls smooth as silk:thumbsup:, way better than that old one.
Here we are all mounted up. The old spring was quite a bit longer, so I just robbed a short one from one of my other motors. (I could have just cut the old one down and that would have worked fine too). I still have to trim the cable back a bit and put an end on it so it doesn't fray. Notice on the actuating arm where the cable goes through is slotted, this allows for the cable to move as the arm travels upward. Way better than my modified snowblower part, now the movement is nice and smooth with no binding whatsoever.
After a little ride time I give this a big thumbs up, I still have to fiddle with my governor adjustment but as far as throttle control, it works flawlessly:thumbsup:
If you are lucky enough to get your hands on one of these you will not be disappointed, it looks and functions EXACTLY like OEM.
Thanks again Joe!!!!!
