Bought a new set of grips and throttle for my Bonanza. They have allen bolts to attach the housing to the handlebar. Is there a trick I don't know about to get the whole throttle from twisting on the bar when I use it? I crank the bolts down to the point where I'm almost bending the wrench or snapping it...still it will twist on the bar. It doesn't twist easily but it will move after some twist pressure is applied. I removed the paint on the bar to see if that might work. Maybe I should primer it to bite down harder. An Ideas? Thanks!:shrug:
