It doesn't look like I can get the motor far enough forward.:doah: Again, I'm still not exactly sure what the length of a TAV is from the center of the driver pulley to the farthest edge of the driven pulley (the back plate I can modify). I know a driven pulley will not fit, the 6" OD is too large. I wish I could get a full scale outline drawing of the tav, then I'd print it out, make a cut-out and try to mock something up around the cutout.
The two speed clutch jackshaft kit is starting to look more promising, but I'm not even sure if I'd have the clearance for the jackshaft mounted clutch, which are usually 4" OD
. But if you see the dimensions in the posted pics, the clutch would probably just fit. I'll contact BMI and see if they'll accept a return if the set-up doesn't fit. No choppy choppy!
