I'm looking for an original Ruttman chrome header. I would prefer one in mint condition, but would consider one in need of re-chroming as long as it isn't bent or dented. I have cash in hand. any leads would be appreciated. Thank you.
I am in need of some professional services. I bought a exhaust but turns out it's not the size the seller said it was. Either way I need a bigger one. I have a very simple design in mind just need one of you guys to make it for me. Needs to have a flange welded on the engine side bc there is no...
Hi, got a Baja MB200 from tractor supply. Got a performance kit from hotrodminibike.
The header is rubbing the frame. They should have had the header bend a little farther out...like even 1/4" would be fine.
As it is, I can't tighten both nuts on exhaust flange down onto the engine head...
Here is a "custom" universal header kit for all engines with 3/4" NPT fittings. (not to be confused with 1/2" NPT which actually measures 3/4" on the outside diameter) This "deluxe" kit includes 8 (YES! 8!) 90 degree pieces with enough little threaded pieces to join them in harmony, 1 piece 45...
I ordered a header the other day that has a o shaped flange but the head on a hemi is D shape, will this be a problem? I noticed the stock exhaust is o shaped.
I have a Predator Hemi and have installed the Stage 1 build up kit from OldMiniBikes.
I did a nice job of painting the header pipe with 500 degree "high temp" paint. Well...I finally got all my last pieces put on the bike and started my engine for the first time tonight.
Wow... the paint started to...
Hi Guys - I just got my paper filter kit (along with a header - lots of popping on deccel so I guess its running rich, filter may help lean it out) for my sons Predator 212 which has been a surprisingly strong engine and held up well! Question is this, being a user of K&N filters in 3 of my cars...
So I ordered the Upgrade kit#1 which includes the new header muffler, emulsion tube, and air filter. When I tried to thread the muffler in to the header, it would barely get together and then just jam, and it gets stuck. I studied the threading on both, and the Taiwan-made muffler looked to have...
So I ordered the Upgrade kit#1 which includes the new header muffler, emulsion tube, and air filter. When I tried to thread the muffler in to the header, it wouldn't fit. I studied the threading on both, and the Taiwan-made muffler looked to have some flaws at the very beginning of the...
I bought this flattie last year for $30. It ran; barely.... Removed governor, Ported and Polished, and added a header pipe. Upon cleaning the stock gas tank, it broke ( the little bowl that the short pickup tube pulls gas out of). I got the idea and plans (from a fellow DIYGK member) to use a...
I hope this is the correct forum. I have a header on my chopper. It is too loud to drive around at shows. I need to tone it down a bit. Got any ideas? It is 1 1/2 " in dia. and about 5 to 5 1/2" in length to work with. If I could find a muffler I would weld it inside. Or a removable baffle. John
