header
  1. snosnake
    Nos speedway widow maker header pipe
    I have a NOS chrome header pipe for the Speedway Widow Maker. 35.00 plus shipping. NOS Air cleaner for same bike 15.00 plus shipping
  2. M
    New GX200 header
    Bought this shorty header off of ArcRacing DJ-1138B. Used for a total of maybe 20 minutes. I swapped out to the HotRodMinibike header and muffler setup. Will take $23 shipped. Saves you about $10 from their website shipped. Pm me for pics, I can text or email them.
  3. vwfan79
    header question
    I know if your header is to big you will lose low end, but will it also rob top end too. My header is 17" long and 3 stage, starts at 1" I think and ends at 1 5/16". I'm running a 26mm Mikuni knockoff, .300 lift cam, eyebrows shaved and mild porting.
  4. deejaaa
    stainless header with baffle
    started with a piece of stainless bathroom grab rail, cut with pipe cutter. marked out flange size needed, cut away most of the extra, bent the lip flat, drilled and bolted to manifold and removed excess flange,
  5. minibikin'
    2 stage header for GX160/200
    Pipe has about two hours on it. I think an OldMiniBikes member made it. Final step is 1.5" od. Should accept the RLV clamp on. It exited under the seat of my Cheeftah and Trail Horse. Should work well on Bonanzas and?? May also fit Predator? $20 + $10.95 Priority Mail shipping.
  6. 125ccCrazy
    wanted: gx390-420 header
    must be in good shape.. prefer 3 stage..
  7. P
    header temp
    anyone know the operating temp of a lightly modded hf greyhound clone at the header? thanks
  8. B
    Header for Predator in Rupp Enduro?
    I'm repowering a '71 Rupp Enduro With a Predator engine and would like to find a header that will bolt up to this combination with no modifications needed. Is there such a thing out there? Thanks.
  9. Cornishrooster
    Single stage straight header for clone
    Single stage straight header for clone (Has a pic now) Bought this for my predator and it matches up fine but it won't fit on my Sears roper since the frame is too narrow. It's still new since I've never fired up the engine yet. From the end of the pipe to the tip of the flange it's 15". I'll...
  10. AJaxMini
    Clinton A500 header
    I'm hoping somebody can help me find an Azusa header for my Clinton project. It's the look I'm really after. I've been shown a couple others but I'm really partial to the Azusa. This is what I'd like to have.
  11. trailramdan
    5 horse Briggs header wanted
    Looking for a header like AplyEdmind has in the link I attached. I need to clear my fender! Not looking to spend a fortune http://www.oldminibikes.com/forum/honda-clone-predator-engines/62441-header-thread-6.html
  12. Hondagx160DB
    Leftover Racing Parts for sale (Mikuni, Headers, Fuel pump...etc)
    -mikuni carb w/ adapter and pulse fitting $60 -fuel pump $15 -Minibike 2 stage header with RLV silencer and bracket $55 -2 stage header with RLV silencer (I had to bend it slightly to fit a minibike, I think it is meant for a kart) $45 -GX160 billet air filter adapter $8 each -2 UNI...
  13. Frank Davis
    WTB Clinton exhaust header 2 stroke d65
    I am looking for a exhaust header for a clinton 65 series 2-stroke engine (al megaphone, or box header, or steel?).....Thanks, Frank
  14. Dragbikemini
    Header
    Mini bike header. AGK, $38 new. $18 plus shipping. Located at Brewster, NY 10509. Thanks for looking! Honda/clone btw
  15. trailramdan
    OldMiniBikes tecumseh header
    wil the OldMiniBikes tec header work on 6 and 7 horse motors?
  16. vwfan79
    Header support
    I have a flat head and was wondering if I can use one of the head bolts to bolt down my header support. The header is 24" long and from what I have read it's better to support it to the motor then to the frame. Is using a head bolt not recommend or will it be ok as long as I torque it down?
  17. crazykart
    Looking For Header Pipes
    i'm looking for a couple of header pipes. 1st, i'm looking for a header pipe to fit the newer style ohv tecumseh engines that are on most of the body, and fun karts out now. i want to modify it into dual exhaust for one of my body karts. 2nd, i'm looking for a header pipe that we used on...
  18. buckeye
    5hp Briggs Header
    Think I need a header for my buildoff bike. The header I was going to use is toooooo looooong. Need a shorter one. If it has the ability to add a muffler would be a plus. PM me with what ya have.
  19. P
    GX390 Header Needed - Anybody have one?
    Anyone have one of these gx390 headers? Just a basic 90 degree header is fine.. It's going on the 390 Clone that I've put into this Baja Warrior.. PM me if you have anything. thanks
  20. waffledude376
    5hp briggs header pipe
    this seems like a silly question but here it goes... This summer I made a header for my 5hp briggs out of a flange i made, a coupler and a 12 inch length of water pipe. My question is do i need tyo run a muffler on the end of this pipe, or will i run the risk of sucking cold ari through...
