I'm building a packmule, bought a 30-series clutch system, and a tecumseh 6.5. My problem is I can't find a source for a belt long enough for this set-up. The driven clutch is a 7", and the closest I can get the center to center distance is 13". I guess I may have to give up the 7" for a 6"...
I posted this in my original thread, but a thread dedicated to the topic may be better. I found the following link while surfing last night. I was trying to find the part numbers for the 18 amp. charging coils for either the Honda GX390 or GX340. Happened across a site that has the coils (or...
I'm looking for a source to buy a bunch of the little gasket on the side of the pulse fed carbs AKA the fuel pump, or a part # I want to have a bunch on hand cause they dry out all the time here in the desert. Amazon or eBay seller would be great, thanks ahead.
My buddy was riding his warrior the other day when the nut came off and went flying. We were unable to find it, but were able to keep everything else. The nut is 16mm, but a fine pitch that hardware stores don't carry. Does anyone have a source for this nut? I've only seen complete jackshaft...
I need a good tubing supplier in the south east michigan area.
So if you know of any please post it up, I need some tubing soon so I can get started on some stuff.
thanks
Before I start searching, I'll ask if anyone here already knows...
I'm looking for 5/8" ID high speed bearings that are .010" or .020" oversize of the standard 1.375" OD...
I want to lathe-true some Azusa Astro and TriStar wheels to remove the wobble...
The plan is to re-bore the...
I've been googling for hours and haven't found out how long a stock DB30 chain is/should be, and haven't found a place to buy a new one.
If I have to buy a chain and reduce the length, that's fine, but need the minimum length to give me an idea.
If anybody is looking for sources for Alky, this place stocks two different brands of racing Methanol. They have branches all around L.A. The only sell in sealed 5 gallon containers though. 25.00 for one and 39.00 for the other brand. plus 4 bucks epa charge.
Sawyer Petroleum Inc. Supplies...
I need a new rear sprocket for my Cat, but it seems to have a weird smaller bolt pattern than the aftermarket ones I see everyone selling. I haven't mic'd it exactly yet but it's close to 2.5 inches. It seems most of them I am finding are on a 2 13/16 bolt circle or similar.
Any pointers on...
Got a lot done this weekend fixing the mess left over from the last owner. The remaining item is to build a seat and I need a source for springs that mount to the rear of the seat. Or any seat suspension ideas for a hard tail mini.
Thanks,
Mike (this is my first attempt at an icon, it should...
Just picked up this project and I am looking for a complete rear brake assembly (with cable and handle) and a seat with rear springs. I believe the rims are Manco.
Also going to rake it a bit and add mini apes.
Thanks,
Mike
Good morning, I'm reasonably new to the mini bike hobby....and am looking for a couple of recomendations for good cheap parts companies.
Can someone point me in the right direction??
THANKS!!! :scooter:
not necessarily looking for an original, but wondering if there are any ..."generic" cover suppliers out there for the Tec H50 engine.
I've tried emailing Brandt at Ruppparts, no reply.
thanks!
I thought I saw some of these mounts at one time but they might have been just some "new old stock" or something. Are they still made or available through anyone? I want some to mount to my mini tent trailer for camping.
