source
  1. Oldschoolcool
    El Tigre spring cup source?
    I am currently rebuilding the front forks on my El Tigre minibike. Does anyone know where I can find the correct size spring cups that the chromed spring sits in? Thanks, Denny
  2. james ackerman
    Source for 4.10/3.50-6 and 4.10/3.50-4 slicks for vintage kart?
    I'm trying to source some slicks for my vintage kart. I'm not necessarily looking for vintage tires but rather some slicks that are race worthy because I don't wanna eat up a nice set of vintage tires. I do however would like a set of Carlisle double Indian head slicks with the same size for...
  3. mini one
    Adjustable hydraulic Shock Source ?
    I've got a message in to OldMiniBikes since I don't see any listed online, which is where I would go first, unless anyone has a pair or could shed some light on some ATV/pit bike/MX/Fox etc ones that would be usable on a Mini bike? (12"-14" or so?) Thanks for any help, PS I know they are way more $ than...
  4. Biffmini
    Possible parts source
    Vintage Parts :: Mini Bikes :: Speedway - Rt 21 Trading Online Catalog
  5. Stitch
    Plain 420 72 tooth sprocket source?
    Hi, Does anyone have any idea where to purchase a plain 70-72 tooth 420 sprocket with no holes? I plan on boring one and drilling out the mounting holes for my CT200U project. I am going with a stage 1 on a H.F. 6.5 212cc Hemi with a TAV 10 tooth driver. Thank you~ Stitch
  6. gran_pann
    Shaving Eyebrows: Any authoritative source on this?
    Hi all, I recently got into a heated debate with a guy that says shaving the eyebrows on a briggs 5 hp will decrease performance. Now I understand enough to do a few things on my engine, and I was under the impression that it helps with flow at the cost of compression ratio being reduced...
  7. Arielsq
    Source for Rupp 12" Rims
    Does anyone have a lead on where to find 12" spoke rims for the rupp mini bikes??
  8. H
    New online source for B&S parts
    I just came across a new source for B&S parts. I was looking for a 495606 carb overhaul kit and they had it in stock and it delivered in two days. Not bad. https://www.outdoorpowerdirect.com/
  9. L
    source for DB30S steering stem bearings...
    Hey guys, starting to buy replacement bits for my DB (currently at the powder coaters). I can't seem to locate a source for the steering bearings H.R.M.B.com doesn't stock them and OldMiniBikes was closed for phone calls, but I didn't see it on their site either any help greatly appreciated. Thanks
  10. 125ccCrazy
    Anyone have a source for a 1 piece 4 1/2" band brake?
    I'm looking for a 1 piece brake shoe 4.5" band brake...I've bought 3 now and each one has the two piece lining which fits like crap around the drum, everyone kinks at the split between the linings and does not touch the drum in that area.. all are made in taiwan too so the quality is far from...
  11. Shawnster
    RTS Hydraulic Brake Caliper Source
    Hello all, I was looking for some compatible hydraulic brake calipers for my RTS-SL and I found a source for the pretty much the exact same ones that RT21 Trading sells for half of the price! Here is the link for the 20 Series Tolomatic Hydraulic Disc Brake H20 Series brake Link for the 10...
  12. J
    frijole seat source
    Looking for a source for a nice pleated frijole style seat, any leads?
  13. Belbuekus
    Need a parts source in Tampa Bay area
    Anybody know of any parts places that carry mini bike parts out my way in Tampa, FL? Internet searchs only turn up bicycle shops or crotch rocket racing shops. I need a few things for my Baja.
  14. M
    Working with PHOTOS and how to better manage them on this forum...
    Greetings everyone, Many times you might have noticed you can only upload photos of only a specific size. The magic size is around 6 mb. You can actually post more pictures if they are of smaller size. I use my phone and sometimes the pics end up being over the 6 mb. This problem can be...
  15. 1967 Tempest
    3/8" ID x 1 3/8" OD bearing source
    Looking for the bearing size of 3/8" ID x 1 3/8" OD for Fox Sprite. I would rather NOT cut or drill the forks out for this. Thanks Dave
  16. R
    Rebuild or High Perf. Carburetor Source
    Hey guys.....I know my old 1976 B&S 5hp will run now. I just can't get it to stay running any longer than a couple of seconds. Tank is clean and full and the diaphragm has been replaced. All passages in carb look clean. pour gas in carb or use a little ether, and she starts on 1st or 2nd pull...
  17. S
    frame source for Honda 49cc project ?
    I want to build up a street legal two wheeler. All I know for sure is that it must use the 49cc 4 stroke Honda and I want it to have front brakes. I have never seen any DIY frnt brakes for minibikes, I was thinking of using the entire front fork off of a Mountain Bike with wheel and brake...
  18. E
    Anyone have a part number for a fuel pump from napa or part source for 196cc cl
    Was wondering if anyone had a part number for a fuel pump for a 196cc Honda clone from princess auto, napa, part source or some similar Canadian reseller. Thanks!
  19. vwfan79
    Low profile air filter source
    I just wanted to share a nice looking low profile K&N style filter source. It fits on a stock briggs pulse jet carb and should fit a Mikuni but haven't checked it yet. The website is ADA Racing, the over height is 2", here is a picture of it on a briggs and a link to the site. Pocket Bike Parts...
  20. oldfatguy
    good source for tools
    Wholesale Tool | Industrial Machinery + Tool Supply I have been buying from them for years now mostly for machinist type stuff. the quality is a whole lot better then HF tools. They have some hard to find tools too like keyway cutters. Their prices are good too
