Delray, I seem to remember swaping out the extended camshaft, and side cover, for the shorter cam and side cover with no hole in it, because the clutch didn't fit right, or the cam shaft was in the way of the chain, however, if you just use a small sprocket on the crankshaft, and put the clutch, maybe on the jackshaft that might work, I'm sure if someone can work it out it'd be you, or Salt, he seems to have a good ideal, too, was thinking of using led lights cause of the low voltage requirements, and the high light output, better than a normal bulb, and so many colors, I'm sure once I get caught up on my bike building, I will take some time to research a charging system for a mini bike, and go-cart, love the ideal of having lights and a starter.
dave
