After reading this post yesterday I went out and messed around with my carb. Its a 22mm with a 15pilot jet, needle with the clip one notch down from center (richer) and 127ish (its been drilled) main jet. The engine does start hard when cold, meaning about 5-10 pulls. After reading the above, this would leave me to believe the engine was running lean. I started the engine and warmed it up then tried turning the screw in to richen the fuel mixture, but anything less then 1.5turns out the engine would stall. It seemed to run the best at about 2.75-3 turns out, which indicates it is running too rich and a smaller pilot jet is required. This goes in line with AGK's recommendations of a 12.5 pilot jet. I wonder how it is some of you are able to use a 20 and have it run fine?
A check of the spark plug looks as though it is running lean overall, though I have not done a full throttle run and then checked the plug as my road has about 1/2 to 1 inch of sand on it right now and a 50mph run didn't seem like the right thing to do until it gets cleaned up. Its been about 50 degree's here lately. I'll need to buy some jets and start playing around some more, though I'll need to order them because they are hard to find around here, especially the pilot jet.
This all being said, the engine runs good once started and will idle nice and smooth all day long.
