As the title says Speedometer, RPM, And Temp Gauge for $100. Its a Vapor Trail Tech. Although I'm not installing it on a a Mini Bike it would work very well for one. It comes with mounts that would allow you to mount it on the handle bar of any minibike with round stock tubing 5/8" to 1". It has sensors that allow you to hook up a the speedo, the Rpm's, and the cylinder Head temp via a spark plug copper washer sensor(which comes in 12mm and 14mm sizes order specific) Only thing needed to buy extra is the extension wire since the stock sensor is 12".
This thing does a ton of stuff. Tells you Temps of engine and ambient air. Has top speed, ride time, warning lights (for both High temp and RPM max (also shift light), Clock, Odometer permanent and resettable, also has backlight, RPM's are displayed as a bar graph and as a number (good up to 20,000 rpm's). Can be run on 12 volts and without. Has internal Battery good for stand alone operation with out 12 volts for 500 hours. Dementions are 4 inches wide and 2.5 inches tall and 1.5 inches deep without mounting.
Just thought I'd share.
Also way cheaper than the GO-Kart ones for 300-500 that do similar things.
