I'm hoping the tank mounted on the frame rail (my end game plan) will take care of the fuel issue.
ole4 has said that Mikuni makes a needle and seat to work with a pump if flooding is an issue ... I suspect a Mikuni specific pump would be good correction as well if needed.
Yes, the Nelson is not a permanent exhaust. I will make something suited to the overall look. HOWEVER I do not want a screaming loud mini bike ... I will sacrifice performance if needed.
I will likely make a flange, weld up some 1-1/4" or 1-1/2" tube, run it down to the jack shaft then back to the left side by the rear tire keeping it at or above the frame rail. Is there a baffle or slip-on that will fit? Visual is important.
I will likely make a separate post on this to cast a wider net for ideas.
To the best of my knowledge the ignition and cam timing are non-adjustable on the H50 motorsports engine, at least the 1994 version I have. I have no information on the cam, duration, lift, etc, nada amigo! I know it does not have the compression release that are on the bigger Tecumsehs. It just has the dot to line it up with the crank. The crank and its gear are one piece.
As far as the intake ... for better or worse I made my own ...
https://www.oldminibikes.com/forum/projects-and-rides/143608-dorothy-heald-vt-7-goes-project-2.html#post1121278
No one threw up any red flags so I think it isn't the problem.
I'm not sure what I can do for a permanent tank, I will see where the triple tree comes to when locked at the ends of its travel.
But post up tank pics if you have ideas!!
I'm not hell bent on making one, buying another mans (or womans) art works too!
On the plus side this build is not a race with a deadline or a budget, this is 100% about the journey. It will be done when it feels right.
And thanks to everyone who puts in their 2 cents ... I don't always respond but it all gets read and digested!
Kevin
Sixpac440, if you are for sure your going to put a fuel pump on your bike, you want to makesure you install the correct pump. on that style carb they are not design for fuel pumps and are more for gravity feed. i believe the needle and seat can not hold back alot of fuel presure,but walbro does make a fuel pump that some of the go kart guys use with that carb and works good. turk brothers racing does sell the correct pump that will work for your carb, under $14 +shipping. if you do call them or for anybody else. tell them what carb you are using and they will send the correct pump. also i hat to say this and maybe you already decided on this? but that nelson muffler got to go........
engine really needs a header pipe.:thumbsup: just may help tune that engine better.
nothing to do with your carb/pump issue, kind of curious if you ever check what the timing was on that and where tecumseh motorsports recommends where it needs to be and did you get any info on the cam spec'sfor that engine?
some guy on here that makes cool looking (old school) steel gas tanks. just trying to remember who?
AND YES,,,intake:thumbsup:
