I will take my intake to work and check for leaks ... visually and a "mouth" vacuum test tell me its good.
With the 130 main, 17.5 Pilot, stock air jet and the "kit" intake it really hasn't run better, till it hits 6500.
With your conformation that this carb should be big enough for the motor, my focus is starting to move to electrical.
I talked to someone at ARC and they said the flywheel is good up to 7 grand but not much more.
I don't need to go to 7 grand, but the motor is supposed to do it so that's been my benchmark.
This bike is for trails, dirt, sand, hills, etc .. not balls to the wall street riding.
I'm having clutch issues and will be swapping it out for a TAV, I may not be bumping up against the 6500 RPM problem with a TAV as I wont need to spin it that fast to get my desired result.
The Mikuni setup when dialed in went to 6000RPM beautifully.
The Nelson exhaust will be going. I want to make a pipe and put a slip-on type muffler. The Kart muffler may be what's needed ... I will look into that more a little later after I get the TAV in place.
Kevin
Kevin
These are my thoughts the carb will more than handle that motor . I have the same carb on a slightly modded Briggs flatty that's screams to 7500 , jets are a 125 main and 17.5 P . The 125 is to rich and fouls plugs after some racing laps , I just change to a new clean plug . The motor runs perfect and I don't want to touch it .
That said I also have another 22 mikuni that does the same thing on a clone that yours is doing falls off about 7600 and is lean . I have drilled jets up to 160 and the same .
This same carb last year on this same motor was dynoed and made 18.83 hp at 7700 and would go to 8500 no problem. So I either have a coil problem or vacuum leak .
I also build my own manifolds and will be really checking for leaks , mine are tig welded and are easy to see holes . I would really check your manifold closely.
Also with that exhaust that I saw there's no way that motor going to run 7 plus . Your going to need a proper header and a nonrestrictive kart style muffler.
