:doah::doah::doah::doah::doah::doah::doah::doah::doah::doah: My God the wheel is round do you want to reinvent it ? 20's and 30's don't mix LOL . I have bought two trikes from people who had the torque converter on backwards and could not figure out why it wouldn't run right. Steve
whats the big issue, its just a question... The 20 series has to be mounted with the spring/hub inboard, I want to run it outboard like a 30...I'm not talking about flipping the sheeves around, the 20 and 30 have the springs wound in opposite directions and ramps that goes both ways, figured with a 30 spring the sheeve will rotate the opposite direction on the other side of the ramps with the clutch flipped so the spring hub is facing out... Some older drivers had ramps that were one direction but the newer ones have ramps that angle both ways....
If those trikes didnt have the springs swapped for ones that are wound the opposite direction then yeah it wont work right, thats obvious..
ut: but I'm not talking about just flipping it around with the stock spring....
as far as re-inventing the wheel, thats called modifying
Just wanted to know if anyone has done this....
